- Thank you received: 690
Vickers Varsity
so i can fit the esc's tomorrow evening and then start planking the rest of the nacelles.
I hope.
- Septic
Tony B wrote: Well i have constructed the bomb aimers cupola today and sorted out the rx hatch.
Did a little bit to the cockpit/ battery hatch as well.
we plod on.
tap - tap.......rivet
carved the blue foam tail cone and glued that on.
Then i sorted out how to join the flaps together.
The snake inner slides into a snake outer that is fixed in the other half of the flap.
Got the flaps and ailerons working.
I need to sort the retract mounts next week and then we are ready for covering and paint.
revised the nacelle design slightly to get it more like the original.
fitted the elevator servos.
did some joint filling on the rest of the fuselage, so it is getting ready for covering and paint.
So tomorrow if i get time after yet more decorating down the hall, i hope to finish sheeting the fuselage and take a look at the retract mounts.
with any luck i can start covering next week.
dummy air intakes made, not fully happy.
i might have to re do them later.
this will be fun............................not.
closest i can find ready made is 75mm from Germany at £15 per leg plus postage. hmmmmmmmmmmmmmmmmmm
trouble is that i need double wheels on every leg, so just bent wire is not going to work.
oh poo bums.
tissue and diamond hard floor varnish.
thought i best try the stuff after telling everyone that is as good as polyc.
plus i had to buy some to do the floors down the village hall. he he he
diluted it down 50/50 with water and so far it seams to be just as good.
- Firewood
- Thank you received: 268
