Auster mk5
but i doubt it will happen for a while.
need to spend hours now cutting holes in wing ribs now.
Looks very nice.
Is that a slight 'adjustment' to the tailplane leading edge shape towards the tip?
Tony B wrote: if i can get hold of some pull pull cables and work out the hinges and get some white solartex, i could finish and cover the tail.
Ha ha , dont know if the first part of the post was directed at me, but if it wasnt, it should have been, as I promised to send you some Tony , and forgot. Will be in the post tomorrow mate, Sorry
well lets put this afternoons work up.
Rudder and elevator clamped in place.
elevator trim tabs made and tacked in place.
Then i sat down and sorted 22 balsa wing ribs.
need to finish 3 more ply ribs still.
out of balsa now, so it will have to go on hold until i get some.
The inner ply wing ribs are all cut and sorted.
wing rods cut, wing sleeves cut.
top of the wing and fuselage is now gluing.
when set i can turn it over and run more epoxy in from underneath and clean up the drips.
wing inner section, not glued cos that wont be done until after the wing has been built.
the wing will have a very slight dihedral, so that when you fit the working struts you will pull the wing down tight so nothing moves (i hope)
thats it now until i get some more wood.
- Inactivated User
With that fantastic structure your Auster really is one that it will be a shame to cover!
fitting these wings to the center section.
i dont want to use nylon wing bolts that intrude into the fuselage as it is all glazed.
soooo what would you gents and sarah,s suggest.
sensible answers Eric and beard.
