Auster mk5
07 Jan 2014 21:32 #151 by Ex-Member
so magnets hidden in the wing root and just the friction from the rods will be ok.
07 Jan 2014 21:42 #152 by Eric
Replied by Eric on topic Auster mk5
I assume you won't be aerobatting it, so yes. If you choose the right ones, they'll give you a kilo or so of pull!
07 Jan 2014 21:46 #153 by Ex-Member
well it will have functioning wing struts as well, so gentle pottering about will be all i ask of it.
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
07 Jan 2014 22:03 #154 by alan cantwell
Replied by alan cantwell on topic Auster mk5
These magnets are also so powerfull that they will interfere with the radio system, ive been advised not to use them in large units onthe LMA forum, for me, 2x inverted L shaped brackets, bolted to the fus rib, into rebated cut outs, with machine screws though the wing, but the cabane would have to be strong for any system to work, free flight model, magnets, for knockoffabilty, for radio, fixed and safe
07 Jan 2014 22:09 #155 by Ex-Member
got you Alan.
will try to make up some mounts tomorrow then.
07 Jan 2014 22:52 #156 by Eric
How can magnets affect a radio? There's no compatibility between magnetic and radio fields.
I've put neodymiums right against my rx's and not a twitch.
Thanks: The Beard
07 Jan 2014 22:53 #157 by old fart
Replied by old fart on topic Auster mk5
But did you move the servos? :P
07 Jan 2014 22:56 #158 by The Beard
Replied by The Beard on topic Auster mk5
Im sure Eric did Owen
07 Jan 2014 23:03 #159 by Fly-Navy
Replied by Fly-Navy on topic Auster mk5
Tony if you haven't sorted out the struttery yet have a look at "The Cub Den" site across the pond. He really has some good ideas on there and that is where I copied my struts from for the Cruiser.
HTH
John
07 Jan 2014 23:08 #160 by Garry Pollard
Replied by Garry Pollard on topic Auster mk5
I have magnets holding most of the battery hatches on , and have never had a glitch, and they are very close to the radio
Have you a link to that info Alan
07 Jan 2014 23:13 #161 by Ex-Member
thanks John, have bookmarked it. lots of useful info in there.
:cheer:
  • alan cantwell
  • Inactivated User
  • Inactivated User
08 Jan 2014 02:32 #162 by alan cantwell
HEY GUYS, just going off what i was told when i did a quiery about holding the canopy onto the big forneir dont shoot the messenger, :blink: you hold the wing on how you see fit, but when you go out in the car, open the window at 50 mph, or even 30 the model will cruise at that sort of speed, and feel the force on the hand, BUT, go for it, should be interesting, meanwhile, i will secure my wings by mechanical means, it the engineer in me, re-inforce the re-inforcment, :)
  • alan cantwell
  • Inactivated User
  • Inactivated User
08 Jan 2014 03:37 - 08 Jan 2014 03:39 #163 by alan cantwell
STREWTH 03.36, and still up coughing me guts up, SO, i thought i would put the time to good use, i have put the following on the LMA forum, and await views,
Bit of a debate going on on another forum, a scratch builder of a 90inch auster has asked for the best advice to secure his wings onto the cabane, he does not want unsightly stuff visible through the glass top, fair enough, but its been suggested he uses these new generation super magnets to hold the wing against the cabane, 1st. i think we will see the wings fluttering prettily down, 2nd, i advised against using them, because i have been advised on here, about placing them too near the reciever, could these magnets up set the radio? i think he is using spectrum, not sure, others have jumped in and said the magnets hold no threat to the radio, but, i am only going off what i have been told on here, anyone have any views?
for the record, i have suggested inverted L shaped steel brackets into 2 rebated slots in the top wing, and bolts through to secure the wings, with the neccasary sub structure to take this attachment, using the strut as a working strut, the Auster is 90inch span
Last edit: 08 Jan 2014 03:39 by alan cantwell.
08 Jan 2014 08:32 #164 by Klipkopwildlife
Replied by Klipkopwildlife on topic Auster mk5
It's changing magnetic field that does the damage, a constant field won't be any problem. Also the magnetic circuit will be closed when the wings are on (just like the Magnet keeper we all saw in Science class at school) there will be very little stray magnetic field. BUT the magnets must be face to face with little or no air gap, so securing them is going to be the trick! Do they do ones with countersunk holes in? You can bolt them to recesses in the surface of the ribs.
08 Jan 2014 12:41 #165 by Ex-Member
drawing up the wing plans today
the wing bits slide on ok.
you can carry the model round by the wing rods now ok.
i need some thinner piano wire to make the rest of the bracing next.
once that is done the cockpit and wing mounts will be 10 times stronger.
Time to create page: 0.331 seconds
