TN 134" LANCASTER
10 Mar 2013 01:43 #181 by Ex-Member
Replied by Ex-Member on topic TN 134" LANCASTER
I thought i would sit down and do some sanding on the Lancaster.
then i did a bit more to number 2
then back to number 1
then started 3 and 4
then back to 2 again
Takes for ever and ever and ever. :(
11 Mar 2013 22:02 #182 by Ex-Member
yet more nacelle building getting done.
we are getting there slowly.
need to start thinking about running all the wires and then fitting the air system for the retracts.
12 Mar 2013 16:47 #183 by Ex-Member
had one of them days today.
the glue i had left setting all night did not hold the rear of the nacelles together when i removed the clamps.
so i have had to do it all again and leave it to set.
gave up and slung the wing in the corner and did a different plane instead.
13 Mar 2013 21:04 #184 by Ex-Member
well i went to unclamp the nacelle this morning and it is holding, so i quickly fixed the 12mm balsa over the top and left to set.
then we re did the rear of the outer nacelle, will finish sheeting that tomorrow if it holds.
then i can blend them into the wing surface and we can get motoring again.
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
13 Mar 2013 22:02 #185 by alan cantwell
Replied by alan cantwell on topic TN 134" LANCASTER
What glue was it Tony?
14 Mar 2013 09:35 #186 by Ex-Member
araldite Alan.
still it is holding now and once the top sheeting is on, it will stay in place ok.
just frustrating as it holds everything up.
14 Mar 2013 10:44 #187 by Grumpy42
Replied by Grumpy42 on topic TN 134" LANCASTER
Tony B. AKA Blooper wrote: well i went to unclamp the nacelle this morning and it is holding, so i quickly fixed the 12mm balsa over the top and left to set.
Tony - when I use Araldite or any other epoxy glue I have had separations as well - particularly if the ambient temperature is low - I've found a little bit of heat from a heat gun thins down the glue and helps it penetrate into the balsa/ply. I NEVER use 5 minute epoxy though - I've found it doesn't penetrate to well before it cures.
14 Mar 2013 15:01 #188 by Ex-Member
well it stuck, so i banged on the sheeting to hold it all together.
need to have a massive sanding day (outside to please the misses) soon.
  • alan cantwell
  • Inactivated User
  • Inactivated User
14 Mar 2013 17:38 #189 by alan cantwell
perhaps you should leave the sanding while sanday get me coat :blush:
14 Mar 2013 19:12 #190 by Grumpy42
alan cantwell wrote: perhaps you should leave the sanding while sanday get me coat :blush:
That one goes over my head - must be a Pommie in joke??? :unsure: :S
27 Mar 2013 17:41 #191 by Ex-Member
Had another look today.
sorted the top gun and turret.
then i took a look at the nose.
fitted the front gun, painted the black a second coat and started making up the bomb aimers section, stuck the 2 windows in the front fuselage.
28 Mar 2013 18:26 #192 by Ex-Member
second coat of paint on the nose and the slide in bomb aimer's section.
cockpit area.
  • alan cantwell
  • Inactivated User
  • Inactivated User
28 Mar 2013 18:30 #193 by alan cantwell
Well, I like it [badass]
28 Mar 2013 19:21 #194 by Garry Pollard
Replied by Garry Pollard on topic TN 134" LANCASTER
Tony, that is looking superb. Thanks a million mate :) :)
29 Mar 2013 09:27 #195 by The Beard
Replied by The Beard on topic TN 134" LANCASTER
Its got seats and everything
Time to create page: 0.349 seconds
